try pulling heater fuse inside truck for sixty seconds with key on it may reset the actuator then disconnect actuator harness and see if when you move to A/C it should make the actuator switch power from one wire to other. if it does the actuator may be bad, see picture.
Mar 13, 2017 at 2:32 AM
