2003 GMC Silverado Power Steering Air
GMC
OUTACONTROL450
I have an 03 silverado and need to no how to get air out of the power steering system. I had to take the lines off and now i can hear air in the gear box and the steering sucks.
Feb 3, 2006 at 2:41 PM
SC1 RACING
  • 117 POSTS
you can remove air by turning wheels slowly all the way to right, then left. go slow or you will foam up the fluid and still have air in. if fluid is foamed up let sit and cool down then refill and turn wheels again.
Feb 4, 2006 at 4:04 AM
Suggested Repair
Bleed air by slowly turning the wheels fully right, then fully left. Turn slowly so the fluid does not foam. If it foams, let it sit and cool, refill, and repeat the slow lock-to-lock turns.
Conversation Summary
The owner of a 2003 Silverado removed the power steering lines and now hears air in the gearbox with poor steering assist. The expert advised removing air by slowly turning the wheels fully right then left, avoiding foaming; if the fluid foams, let it cool, refill, and repeat.
