1988 GMC Sierra Loose Tilt Steering
DARTHLIAM
I have a 1988 GMC Sierra C1500 and the steering wheel is really loose at the area where the tilt is at. What would cause the problem and what can I do to fix it?
May 17, 2006 at 3:51 AM
LOSONE
  • 1,616 POSTS
You have loose bolts where the tilt area connects to the column. You can get to two of the bolts by removing the steering wheel, flex plate and turn signal switch. I have done a lot of them. Good luck
May 17, 2006 at 4:42 AM
Suggested Repair
Tighten the loose bolts where the tilt mechanism connects to the steering column. Two bolts can be reached by removing the steering wheel, flex plate, and turn signal switch.
Conversation Summary
The owner of a 1988 GMC Sierra C1500 reported a steering wheel that was very loose at the tilt area and asked for the cause and repair. The expert said the bolts connecting the tilt section to the column are loose and that two of them can be accessed by removing the steering wheel, flex plate, and turn signal switch.
