2004 GMC Sierra Left Turn Steering Whine
QWAZYMIKE
GMC 2004 Sierra 59000 miles.
I have a noisy steering problem, happens when only making left turns, this usually happens at slow to moderate speeds making a left turn at intersections.
The belts are good and fluid levels are good.
Jun 3, 2006 at 2:00 AM
SYNCRAIT
  • 235 POSTS
what do you mean when you say noisy what kind of noise? a clunk, a click, a screech, plop, boing, ribbit
Jun 3, 2006 at 6:33 AM
QWAZYMIKE
whining noise, like a flat guitar
Jun 3, 2006 at 8:22 AM
LSUSSEL
  • 252 POSTS
A whining noise is an indaction that you need to add more power steering fluid and or that your rack of pinion is going, when you add this power steering fluid make sure you turn the steering wheel all the way to the left as far as it will go and then all the wheel all the way to the right as far as it will go, to get all the air out of the lines. hope this helps.
Jun 4, 2006 at 6:12 AM
Suggested Repair
Add power steering fluid if low and bleed air by turning the wheel fully left, then fully right. If the left-turn whine continues, the rack and pinion may be failing and should be inspected.
Conversation Summary
A 2004 GMC Sierra with 59,000 miles makes a guitar-like whining noise only during left turns at slow to moderate speeds. Belts and fluid levels were reported as good. An expert said the whine can mean low power steering fluid or a failing rack and pinion, and advised adding fluid while turning the wheel lock to lock to bleed air from the lines.
