1993 GMC Sierra Power Steering Squeal
JRSIERRA
  • 9 POSTS
GMC Sierra 1500,1993,200,000k, The power steering pump sqeals until i drive for a few minutes only when it's below -20 outside. Why??? anybody know? it sounds terrible!
Nov 23, 2006 at 3:08 PM
LSUSSEL
  • 252 POSTS
How many miles do you have on the vehicle?
Nov 30, 2006 at 1:57 PM
JRSIERRA
  • 9 POSTS
It says 200,000 k on the original question, maybe u just missed it, let me know thanx alot
Dec 1, 2006 at 5:04 AM
LSUSSEL
  • 252 POSTS
Sounds like you need to replace the power steering pump, but before you do that, check to make sure your power steering fluid level is full. That also might be the issue
Dec 12, 2006 at 2:12 PM
Suggested Repair
Check that the power steering fluid is full. If the level is correct and the cold-weather squeal continues, replace the power steering pump.
Conversation Summary
The owner of a 1993 GMC Sierra 1500 with about 200,000 km reports that the power steering pump squeals until the truck is driven for a few minutes, and only when it is below -20 outside. The expert advises confirming the power steering fluid is full before replacing the pump.
