my son put power steering fluid in the brake system.How do I flush the system,and what parts should be rebuilt or replaced. Thank You,Chris
Apr 17, 2007 at 7:46 AM
Remove the contaminated fluid from the brake reservoir before it is pushed through the system, refill with fresh brake fluid, and bleed the system thoroughly. Inspect rubber components and the ABS unit, which may be damaged.
The owner says power steering fluid was put into the brake system of a GMC and asks how to flush it and which parts to rebuild or replace. The expert advises sucking out the reservoir first, refilling with fresh fluid, and bleeding thoroughly, while noting that rubber components and the ABS unit may be damaged.
