2002 Chevrolet Silverado 1500 Low Coolant Light Comes On
2002 CHEVROLET SILVERADO 1500
JDGCOLLECTOR
i have a 2002 chevy silverado 1/2 ton pickup with a 4.3 vortec engine. on a few ocassions the low coolant light will come on, but the coolant doesn`t appear to be low.
even though i have detected the odor of coolant, a few times, and once i saw what appeared to be coolant on my garage floor. but that has been some time, and i haven`t seen it since, it was a small amount.
i also might say that the light always goes off, after the engine has been restarted.
thanks
Steve
Feb 24, 2006 at 12:10 AM
MVANNESSJR
  • 223 POSTS
Your coolant level sensor may be malfunctioning or it just gets stuck every once and awhile. It's located in the coolant reserve tank. My car randomly spews coolant out of the reserve and the low coolant light comes on at times... I've replaced the sensor and it happens less often but it still does it. Probably nothing to worry about, just keep an eye on the coolant level.
Feb 24, 2006 at 4:05 AM
JDGCOLLECTOR
Thanks for the information, i will continue to monitor the situation.
Feb 24, 2006 at 4:11 AM
Suggested Repair
Inspect the coolant level sensor in the reserve tank, which may be sticking or malfunctioning, and continue monitoring the coolant level for any loss.
Conversation Summary
The owner of a 2002 Chevy Silverado 1/2 ton with a 4.3 Vortec reports that the low coolant light comes on occasionally even though the coolant does not appear low, then goes out after a restart. A coolant odor and a small amount of coolant on the garage floor were noticed some time earlier. The expert suggests the reserve-tank coolant level sensor may be malfunctioning or sticking and advises keeping an eye on the coolant level.
