Chevrolet Silverado Heater Fan Squeals
TFURPHY1
When I run my heater, the fan squeals. Can I repair this by lubricating the motor shaft? where is it located?
Thanks for helping
Feb 15, 2007 at 4:17 AM
CHEVY22
  • 1,375 POSTS
you can try it but most likely you will be replacing it , they are not expensive and easy to replace , right side of engine compartment at the firewall look for a round object with approx 6 bolts in it,
jim
Feb 16, 2007 at 8:45 AM
Suggested Repair
Lubricating the blower motor shaft can be tried, but replacement is more likely. The motor is inexpensive and easy to replace; it is on the right side of the engine compartment at the firewall, in a round housing held by about six bolts.
Conversation Summary
The owner says the Silverado heater fan squeals and asks whether lubricating the motor shaft will fix it and where the motor is located. The expert says lubrication can be tried, but the blower motor will most likely need replacement. It is inexpensive and easy to replace, located on the right side of the engine compartment at the firewall as a round unit with about six bolts.
