GMC Jerky Steering on Curves
GMC
WRAPUMUP
The steering wheel has been jerking especially on curves. One place has replaced the pitman arm a couple of times. It is still doing it. Another place unhooked a switch on the column, something like a steering sensor? Anyone heard of this and what is the official name? It seems to have quite, now i want to price and find the item somewhere. Thanks for any help!
May 22, 2006 at 2:05 AM
LSUSSEL
  • 252 POSTS
Did you check the rack of pinion?
May 22, 2006 at 5:26 AM
WRAPUMUP
No I didn't, but the shop who replaced the pitman arm was supposed to check the whole front end out. It has quite doing it since the second shop unplugged this so called sensor, so ...
May 22, 2006 at 6:05 AM
LSUSSEL
  • 252 POSTS
Yes, but I think that this sensor should be plugged in. You dont want to drive a car around without parts and sensors hooked up. You should have it looked at by someone else
May 22, 2006 at 6:20 AM
Suggested Repair
Reconnect the steering-column sensor and do not drive with it unplugged. Have another shop inspect the rack and pinion and the rest of the front end.
Conversation Summary
The owner reports jerky steering, especially on curves, after the pitman arm was replaced more than once. A second shop unplugged a column switch or steering sensor, and the jerking stopped. The expert says the rack and pinion should be checked, the sensor should be reconnected, and another shop should inspect the vehicle.
