my 1987 S10 chevy blazer wont start I suspect it may be the fuel pump relay but where can I locate it?
Apr 15, 2006 at 8:29 AM
Locate the fuel pump relay on the firewall. It only primes the system for 3-9 seconds; power then goes through the oil pressure switch to the pump. Check all fuses, find the unplugged green connector, and apply 12V. If the pump runs, the pump itself is confirmed working.
The owner of a 1987 Chevy S10 Blazer that will not start suspects the fuel pump relay and asks where it is located. The expert says the relay is on the firewall and only primes the fuel system briefly, with the circuit continuing through the oil pressure switch to the pump. They advise checking all fuses and applying 12V to an unplugged green connector to see whether the pump runs.
