1993 Chevy S10 Blazer Hard Warm Start
E90SUPRAT
Hello, I have a 93 s10 blazer 4.3l(w) with 47000 original miles and I'm having some minor problems with it. It starts right up when its cold, but when its warm, it takes a while (5-10 secs. of cranking while pressing the gas pedal) before it will start. When it does start, it will shoot a cloud of smoke and black carbon out the exhaust, and it will also idle rough and surge. It mainly happens when it is warm outside or the engine is warm. It runs fine while driving, but will idle rough when at a stop. I have replaced the IAC and the TPS, and the EGR was just serviced. The truck is in such good shape with super low mileage, so I'm really confused as to what could be wrong with it, any suggestion would be appreciated.
Thanks, Ed.[img:2eaaf17dcc]http://www.2carpros.com/forum/automotive_pictures/70246_DSC007621_1.jpg[/img:2eaaf17dcc]
Apr 22, 2007 at 6:23 AM
2CARPRO JACK
  • 11,533 POSTS
Your looking at two possibilities.The first being the fuel injectors or "spider" as it is called. They go bad alot and dump raw fuel into the intake causing hard starting. On your truck it has to be replaced as a whole unit. The other is the pulse dampener un the top of the fuel pump. When it goes out it lets the fuel pressure bleed down causing a hard start condition. Your truck sounds more like the injector. If you remove the alumnum upper plenum you will see the injector. If the regulator is blown there will be puddles of raw fuel and a very clean spot in the intake under it
Apr 26, 2007 at 3:22 AM
GM2MOM
  • 11 POSTS
o2 sensor
Nov 29, 2010 at 8:28 AM
GM2MOM
  • 11 POSTS
Check all of your sensors before buying a spider assembly. You can see if the spider is leaking by taking the top off. check the pressure regulator and the knock sensor. they get broken sometimes when changing plugs by a mechanic. they may not know it, or just not tell you they broke the connector. this will cause it to mess up the timing and fuel ratio.
Nov 29, 2010 at 8:32 AM
Suggested Repair
Inspect the central-port (spider) injector assembly by removing the aluminum upper plenum; raw-fuel puddles and a clean spot indicate a failed regulator that should be replaced as a complete unit. Also check for fuel-pressure bleed-down from the pulse dampener on the fuel pump, and verify the oxygen sensor, pressure regulator, and knock sensor before replacing the spider.
Conversation Summary
A 1993 Chevrolet S10 Blazer 4.3L starts easily when cold but cranks 5-10 seconds when warm, then emits black smoke and carbon and idles rough or surges. It runs fine while driving. The IAC, TPS, and EGR have already been addressed. An expert said the spider injectors often leak raw fuel and cause this, or the fuel-pump pulse dampener may let pressure bleed down, with the injector more likely. Another reply suggested checking sensors, the pressure regulator, and the knock sensor before buying a spider assembly.
