1993 Chevy S-10 Blazer No Start
LADYBUG_IOWA
  • 5 POSTS
I have a 1993 S10 Blazer 4.3 l 4x4 with approximately 125,000 miles, And the truck will trun over but wil lnot start. We have replaced the relay, the fule pump and the fuel filter, and our mechanic has even replaced the gas tank, because it was all rotted out. Today he change the fuel injectors, thinking that was the reason why the vehicle is not starting however that still is not the problem, he says that there is plenty of fuel pressure behind it and that there is know no reason for it not to start. I will turn over but will not start. We have replaced the battery also. As you can tell this truck needs alot of work, we reinheriated back from someone in the family. Any suggestions on what we can have our mechanic check. We and him are at a loss as to what could be wrong with it, Oh yeah also if he sprays ether on the components it starts and runs until it burns off then it dies again and will not restart. And also he has noticed that heater core is shot on it too, Please any suggestions as to what to check and what to do would be great. Thanks
Jul 20, 2007 at 9:22 AM
CLY
  • 308 POSTS
"Oh yeah also if he sprays ether on the components it starts and runs until it burns off then it dies again and will not restart."
That statement tells me that the truck has spark, but does it have injector pulse??? I would say that there is something going on with the fueling system.If it will run off of carb cleaner.Maybe a quad driver problem in the engine control module...
Just something to think about
Cly
Jul 20, 2007 at 2:11 PM
LADYBUG_IOWA
  • 5 POSTS
It does have injector pulse and we change the ECM valve and still nothing. Thanks for the thought though.
Jul 20, 2007 at 2:21 PM
CLY
  • 308 POSTS
ok....The problem is with the fuel system. Does that have the one injector that goes threw what they refer to as a spider type deal with the injector nozzles on the end of them? I would make sure that no terminals are bent at that connection there has to be something to it right there, I am assuming that he is checking the injector pulse at that connection.If you are spaying stuff in the intake and it runs then the problem is that you are not getting fuel.I dont have a shcematic that I can look at here at home. I will look into it Monday and post more then. If you come up with anything else feel free to add it.....
Cly
Jul 20, 2007 at 2:42 PM
Suggested Repair
Because the engine runs on ether, spark is present and the no-start is a fuel-delivery problem. With injector pulse and fuel pressure already confirmed, inspect the central spider injector connector for bent or poor terminals and verify pulse and fuel flow at that connection.
Conversation Summary
A 1993 Chevrolet S-10 Blazer 4.3L cranks but will not start after the relay, fuel pump, filter, tank, injectors, battery, and ECM were replaced. Fuel pressure and injector pulse are present, and it runs only while ether is sprayed, then dies. The expert concluded spark is good and fuel is not reaching the engine, and advised checking the spider injector connector and terminals.
