GMC Small-Block 400 Carb Backfire
GMC
B_KELLER46
The question i have is, the engine in my truck is a smallblock 400, bored 40 over, 11.5 to 1 comp, big cam, not sure of specs, single plane manifold, 850cfm edelbrock carb, after warming up the engine and goin to take off, it backfires up through the carb at times, i've been told it sounds like i need a little more advanced timing. the engine is a 1979 motor rated at about 475+ horsepower. any ideas?.also discovered tonight, that after driving for a bit, now it wants to diesel on me now.....lol, when it rains it pours....lol. thanks.
Brian
Mar 15, 2006 at 3:44 AM
MICKEY-D
  • 304 POSTS
Sounds to me like you could have one, or several things wrong. Definitely check your timing, also your carb air/fuel adjustments could be too lean,even a partially fouled plug, or loose/arcing plug wire. Start checking !
Jan 8, 2010 at 8:05 AM
Suggested Repair
Check ignition timing, carburetor air/fuel mixture for a lean condition, spark plugs for partial fouling, and plug wires for looseness or arcing.
Conversation Summary
Owner of a GMC truck with a modified 1979 small-block 400 reports backfiring through the carburetor after warmup and run-on after driving. Expert recommends checking timing, a possibly lean carburetor mixture, fouled plugs, and loose or arcing plug wires.
