1984 GMC back fire when you let go of the gas
GMCONYX
1984 GMC Sierra Classic 150,000 5.0 engine
The old carburator blew the catlitic converter and muffler I changed the carburator no I have a handme down holley straight form another engine and the truck still pops loudly when I release the gas going don the freeway, it sounds like cannon fire. Also when I rev up the engine in the drive way and release the gas it also pops loudly. I don't want to change the mufflers yet otherwise it could blow them again. Please Advise me on what it could be.
I just finished changing out the motor this past weekend it was smoking and it wasn;t going to pass the emmissions test. It was popping before the motor change and is still popping after the motor change. I installed a short block.
Thanks for you help with this. !!!!!!!!!!!
Mar 9, 2007 at 2:57 AM
  • 31,937 POSTS
Hi there,
It sounds like that the engine may have a vacuum leak and it is running very lean, check around the carby with a small hose held to your ear & inlet manifold. you will soon hear a leak. (keep away from fans and belt) also chek all vacuum hoses for condition, they should be soft not hard & cracked also check ignition timing, and also the carby float levels are not to low,check ignition leads for cross fire, but my money is on a vacuum leak.
Mark (mhpautos)
Mar 13, 2007 at 5:01 PM
JD329
  • 16 POSTS
Sounds to me like it could be a firing problem. Check all of the components under the distributor cap.
Apr 27, 2007 at 6:56 AM
BLANTON1276
is the belt still on the air pump? if it is take it off.
Jul 24, 2007 at 10:26 AM
THATONEGUYWITHTHETRUCK
my moneys on the distributer cap as well. could be a leak in the vacuum lines, i had the same problem with my truck for a while, same year and model and make, check your lines, and it could be a firing problem
Dec 20, 2010 at 11:40 AM
