1997 Buick Regal Intermittent No Start
1997 GMC
RANMANYO
My car will not start sometimes. The instrument panel will do all sorts of weird things: the speedodometer will jump, the ASB light will come on, the engine will not turn over. The battery seens fine; however, when I have the key turned on and it will not start, I can try to turn the blinkers and it will shut the entire car down. Any suggestions. I have also taken it to a dealership and they once put a new CPU(the computer brains) in and it worked better for awhile.
Apr 12, 2006 at 5:26 AM
LOSONE
  • 1,616 POSTS
It sounds like you have a classic ground problem. Check the ground from the battery to the engine, the engine to the body and the battery to the frame. Remove and clean them all it should solve your problem! Good luck
Apr 12, 2006 at 5:45 AM
Suggested Repair
Clean and retighten the ground connections from the battery to the engine, the engine to the body, and the battery to the frame.
Conversation Summary
The owner of a 1997 Regal reports an intermittent no-start with erratic instrument-panel behavior, including a jumping speedometer and a warning light, and says using the blinkers with the key on can shut the car down. The battery seems fine, and a dealer computer replacement helped only temporarily. The expert identifies a classic ground problem and recommends cleaning the battery-to-engine, engine-to-body, and battery-to-frame grounds.
