1996 Buick Regal Won't Start After Overheat
QUARTRZ
I have a 1996 Buick Regal GS, 112,000 miles, 3.8 liter (3800 Series) and while I was driving the check engine light started flashing and the temperature gauge started to skyrocket. I pulled over to check the radiator and it was empty. I put a gallon of water in it, started it, put it in drive and it coughed out a cloud of smoke (don't know what color 'cause it was at night) then started running sluggish. I pulled over again, put some water in it, and now it won't start.
I was told it may be a bad head gasket. What do you think?
Mar 9, 2007 at 1:35 PM
2CARPRO JACK
  • 11,533 POSTS
sounds like it could be. pull the spark plugs and turn the engine over, look for water coming out of the plug hole/holes.Water doesnt compress, dont try to turn the engine over until the plugs are out or you could do serious damage to the botom end .
Mar 9, 2007 at 11:57 PM
Suggested Repair
Remove the spark plugs and crank the engine to check for water coming from the plug holes. Do not crank with the plugs installed, because water does not compress and can cause serious bottom-end damage. This checks for a possible blown head gasket after overheating.
Conversation Summary
The owner of a 1996 Buick Regal GS with a 3.8L engine reported a flashing check engine light and a rapidly rising temperature gauge. The radiator was empty; after adding water, the engine smoked, ran poorly, and then would not start. A bad head gasket was suspected. The expert agreed that was possible and advised removing the spark plugs and cranking to look for water from the plug holes, warning not to crank with the plugs installed.
