Right now the AC is not operational, when you Start the truck and try to turn it on the AC indicator on the control flashes and the fan comes on.
If I disconnect the battery for about a minute and re connect, start the truck and turn the AC on it blows very cold air and will run for several hours without a problem. BUT when you try to drive the truck it will stop within a minute of leaving the driveway, the AC compressor stops operating and the AC indicator on the control starts flashing. The only way to get it working is to disconnect the batteries again.
