2005 GMC Envoy HVAC Speed 5 Fails
BKSTEV
My max setting on my HVAC (level 5) does not work on my '05 Envoy. Speeds 1-4 work fine but on 5 it just turns off. Does anyone know what would cause this? I checked the fuses and they all seem fine. Someone mentioned to me to check the relay but I did not see a relay pertaining to either the HVAC or the blower motor in the manual. Any help with this would be appreciated.
Aug 17, 2007 at 12:28 AM
SERVICE WRITER
  • 9,123 POSTS
There is a technical service bullitin out for that. It entails replacing the blower motor resistor module AND it connector. #35 fuse ( in underhood box) needs to be pulled out first before changing. Resistor is in behind the right hush/closeout panel . (I'm not sure if that is the kick panel or under the glove box.)
Aug 17, 2007 at 12:58 AM
Suggested Repair
Per the TSB, replace the blower motor resistor module and its connector. Pull underhood fuse 35 first. The resistor is behind the right hush/closeout panel.
Conversation Summary
The owner of a 2005 GMC Envoy reports that HVAC blower speeds 1-4 work, but speed 5 shuts the blower off. Fuses were checked and no HVAC or blower relay was found in the manual. An expert cites a TSB calling for replacement of the blower motor resistor module and connector after pulling underhood fuse 35. The resistor is behind the right hush/closeout panel.
