vibration in in drive and rev. and slightly in neutral and very high vibrations with the ac on.It calms down a little after driving for about 20 mins. and neutral seems to stop. I cleaned the thottle body, oem mounts incl.the trans,plugs(boche double plat),fuel filter,and basic oil change.I seem to hear a air/fluid build up when starting and when shuting off i hear a shoosh air release sound;and if helps when starting somes times its one big booming then sometimes its smooth as day one and then the slightly delay
Aug 11, 2013 at 11:02 AM
