1968 GMC Pickup Milky Oil in Rockers
1968 GMC
JOHN FOX
My 1 1/2 year old, 305 CI long block, is starting to collect emulsified oil in the rocker arms. This is not being seen on dip stick, or in drained oil.
Is this a intake gasket, or head gasket problem?
Please don't tell me I might have a cracked block!
Thank you
Dec 15, 2006 at 10:14 AM
MICKEY-D
  • 304 POSTS
I believe what you are describing is sort of normal condensation buildup from a poorly vented engine. Make sure the valve cover vent is clean, and the PCV valve is working properly.
Jan 7, 2010 at 3:42 PM
Suggested Repair
Clean the valve cover vent and confirm the PCV valve is working properly. Emulsified oil in the rocker arms is likely condensation from poor crankcase ventilation rather than a gasket or cracked block.
Conversation Summary
The owner of a 1968 GMC pickup reports emulsified oil collecting in the rocker arms of a 1.5-year-old 305 long block, but not on the dipstick or in drained oil, and asks whether an intake or head gasket is the cause. The expert says this is typically condensation from poor ventilation and recommends cleaning the valve cover vent and verifying that the PCV valve works.
