1983 GMC Pickup Intermittent Stall
1983 GMC
NICHOLE
i have a 1983 GMC pickup miles are HIGH. it will run fine for weeks sometime months but then it will die while i am idling or even driving sometimes it will start back up right away but sometime it takes a day. last time it happened it would start and run then when i put it in any gear it cut out. does anyone have any ideas what this could be, besides that its OLD. :?
Mar 14, 2006 at 11:05 AM
RAYHUT
  • 134 POSTS
okee dokee. sounds like you need a new coil and replace your voltage regulator.
Mar 14, 2006 at 10:30 PM
PLABBE
  • 12 POSTS
when it stalles and wont start again I hit the ecm under the dash a few times and it starts and its good to go until it does it again .Sometime its good for a long time and other times just a few minutes but now I dont have to weight until the truck is ready to go .
Jul 17, 2007 at 2:01 PM
Suggested Repair
Replace the ignition coil and the voltage regulator.
Conversation Summary
A high-mileage 1983 GMC pickup runs normally for weeks or months, then stalls while idling or driving and may not restart immediately, sometimes not for a day. It can also start and then cut out when shifted into gear. An expert suggested replacing the ignition coil and voltage regulator. The owner later said tapping the ECM under the dash sometimes gets it started until the problem returns.
