2001 GMC Jimmy will not start
RANDY12121
  • 2001 GMC JIMMY
  • 6 CYL
  • 95,000 MILES
Died going down the road. It will turn over but will not start. Fuel filter and pump is good. What should I do next?
Saturday, January 12th, 2008 AT 4:17 PM
MASTERTECHTIM
  • 4,750 POSTS
Do you have spark? How do you know the pump is good? If you have spark try spraying starter fluid into throttle body and see if it starts.
Saturday, January 12th, 2008 AT 4:22 PM
RANDY12121
I removed the filter and turned the ignition, fuel came out. I also blew through the filter, it is not clogged. How do I check for spark?
Saturday, January 12th, 2008 AT 4:29 PM
MASTERTECHTIM
  • 4,750 POSTS
I know this may not make sense but just because fuel comes out of fuel filter, it does not mean you have enough pressure or volume. To check spark the easiest way to do it in your driveway without the right tools is to put a spark plug into the plug wire and crank engine and see if it sparks. If it does not, remove the wire at the coil tower and crank it and then see if it sparks. Check back after you do that.
Saturday, January 12th, 2008 AT 4:49 PM
