I can tell you it is getting 55-60 lbs of pressure now. There are no codes showing up. Also, the battery checks out to be fine.
The mechanic said he did some research and found that if the vehicle is on and you remove this one relay from the fuse panel, the car is suppose to remain on. He said if the relay is removed and the engine shuts off, it is suppose to mean the oil pressure is bad. This is why the switch was replaced.
Please help find the problem. We badly need our cars working so we can get to work.
SPONSORED LINKS
Tuesday, January 13th, 2009 AT 9:52 PM
