If your saying it cranks good, but, won't start, can you check for codes?
If not, try some of the basic tests. Have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, check fuel pressure. You need a gage for that.
Those spider fuel systems are known for problems, may be it will be something else?
SPONSORED LINKS
Friday, January 2nd, 2009 AT 12:25 PM
