My truck will turn over but will not start, any Idea what it may be?
TAISAICAN_00
  • 1998 GMC JIMMY
My truck will turn over but will not start, any idea what it may be. When gas is put in carb in front the truck will start. What is wrong?
Monday, February 9th, 2009 AT 12:57 PM
Do you hear the fuel pump when you turn key to run? If so check the fuel pressure and then comeback with the readings
Monday, February 9th, 2009 AT 1:23 PM
SPAZZZYLUV
  • 8 POSTS
Need to know if you figured out the issue with your truck because Im having the same exact issues. Please let me know. Greatly appreciate
Saturday, May 22nd, 2010 AT 4:31 PM
CHRISXXX9876
I'm having same problem with 98 Jimmy, Did you ever find out the problem?
Thursday, August 25th, 2022 AT 9:28 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
When you turn the key on without cranking the engine over do you hear the fuel pump running in the tank? Also will it run if your spray starting fluid into the intake? Do you have spark? These videos and guides can help us get your engine running again.
https://youtu.be/baq_aEWNQ0Y
and
https://www.2carpros.com/articles/car-not-running-advanced
Thursday, August 25th, 2022 AT 11:18 AM
