1998 GMC Jimmy Died, no start no spark , have good fuel pre
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
PESCADO63
1998 4x4 jimmy 4.3 engine.. For months would drive along and stall,, wait a few minutes start back up on go on your way for few miles and do it again.. Sometimes go for long distances without stalling.. Then 3 weeks ago died and has not restarted since.. Have replaced ign mod, crank sensor, tested coil.. Still no spark.. Have good fuel pressure.???? Could it be VCM or maybe a bad coil still.. All terminals of coil read less than 1 ohm.. No matter what I have done, coil does not produce spark.. No trouble codes etc.. Thanks
Terry
Jan 17, 2010 at 2:36 PM
  • 75,988 POSTS
All terminals of coil read less than 1 ohm, what about the seconday resistances negative of coil to the coil tower, check also the distributor pick-up coil and the ignition control module.
Jan 17, 2010 at 3:25 PM
PESCADO63
[quote:f830e4eeeb="rasmataz"]All terminals of coil read less than 1 ohm, what about the seconday resistances negative of coil to the coil tower, check also the distributor pick-up coil and the ignition control module.[/quote:f830e4eeeb]
Secondary tower to primary 5.5 ohms as prescribed.. Read in mitchel that pickup in dist for cam is for injection timimg and refernce only! I have three ign mods and all three run in Gmc van.. I have been there with this one.. Can it be the VCM??
Terry
Jan 18, 2010 at 3:20 AM
