1997 GMC Jimmy
TERESA TRAMMELL
  • 1997 GMC JIMMY
Other Category problem
1997 GMC Jimmy Engine Size unknown Two Wheel Drive Automatic 300000 miles
Truck will not start but it turns over I have checked the fuel pump, starter, alternator, battery, relay, any suggestions?
Tuesday, January 8th, 2008 AT 11:11 PM
BLACKOP555
  • 10,371 POSTS
Try some starting fluid sprayed directly in the throttle body, if it fires up its a fuel problem if not its probably spark related, check for spark at each cylinder, should be bright and blue.
Post back if more assistance is required.
Wednesday, January 9th, 2008 AT 8:18 AM
