1997 GMC Jimmy 97 Jimmy will not start **
ALRIGHT
  • 1997 GMC JIMMY
  • 6 CYL
  • 4WD
  • 115,000 MILES
My 97 Jimmy has been parked and not ran since April. It did not have any issues starting when I parked it. Upon trying to start it recently, it will not start. It sits cranking indefinitely.
I've put in 6.5 gallons of fresh gas. I have checked 2 spark plug wires and have spark from both of them. When I removed one of the spark plugs, it was wet with gas. The distributor was a little loose, I tightened it down. The Check Engine Light is on so I'll be grabbing an OBD reader to check the codes, but I wanted to get some possible dialog going on this.
Any ideas?
Sunday, October 11th, 2009 AT 11:15 PM
Check the fuel pressure to rule out the fuel filter, intank pick-up sock and fuel pump.
Scan the computer for code/s
Monday, October 12th, 2009 AT 12:31 AM
ALRIGHT
If the pressure is within spec, it eliminates all 3 of those components as suspects? I'll check that along with codes soon and get back to you.
Monday, October 12th, 2009 AT 12:39 AM
ALRIGHT
Bought a $52 pressure tester; pressure was fine. I had the inclination last nite to check the dizzy for corrosion but decided against it as I was tired. Oops, should have done that before spending $52. Cap & rotor had pretty bad corrosion on the contacts. Scraped them clean(er) and it started without much issue.
Wonder if I can return this tester :x
Thanks for the help anyhow
Tuesday, October 13th, 2009 AT 2:22 AM
