Please help me ! 1997 GMC Truck will now not start
LAWLESS1
  • 1997 GMC C1500
1997 GMC K1500 4x4 auto. X.C. 25000 ks. Last friday my fuel pump died I was positive it was the pump as I could no longer hear it. I chaged the pump and the truck ran bad really poorly. I took it to Candain Tire had the Fuel Pressure Checked an it was very low so I exchanged the pump put in another. Truck ran great for 2 days yseterday while driveing down the highway I tried to make a pass and the the truck reved but gave no power. A little later I had a hard time starting it. It took a while but fired and when it did it spit and sputtered a bit. Took while to start this morning then a little later I could not get it to start again. I hear the pump going. Turns strong before I killed the battery. But just no fire. Yes I changed the filter as well checked for loose connection where I hooked up the pump all is well. I am confused what are the odds of getting tow brand new bad fuel pumps or what else may it be. Any help will be greatly apriciated. IF I find this site usefull I will crtanly not be shy of making a donation. Thank You Very Much
Friday, May 11th, 2007 AT 10:59 AM
DWHITE
  • 14 POSTS
Sounds to me like you have a restriction in the fuel line betwwen the pump and the engine. But I don't do this for a living. Just an educated guess from me trying to help. Open both ends of the fuel line and blow it out with air. Or it might be plugged in the take. I believe the pick up tube in the tank has a screen on it. Happened to me once and it was that screen partially plugged with crud
Friday, May 11th, 2007 AT 6:12 PM
2CARPRO JACK
  • 11,533 POSTS
Did you replace the fuel pump relay as well? And the fuse? The A/C Delco pumps come with a new plug to wire in and a new fuse. Sometimes the old pump drawing too much amperage can hurt the relay. What brand of pump?
97 is that a CPI injection?
Monday, May 21st, 2007 AT 8:18 AM
