Yes, I know.
Spray starting fluid in intake (throttle body) to rule out fuel. You will have to remove connecting hose from filter box to TB.
If it doesn't run s few seconds, then fuel is eliminated as a cause.
Then remove module and have it tested.
Generally when modules fail, they will fail when engine is hot, then work again when engine cools down, then failing again when hot.
Wednesday, May 26th, 2010 AT 7:48 AM
