1995 GMC Sierra Funny Idle
95GMC1500
i have a 95 gmc 1500 serria with a 5.7 V8 and when i give it a little bit of gas once it goes back down to an idle it idles funny and then goes back to a normal idle
May 25, 2007 at 7:18 PM
  • 75,988 POSTS
[quote:af37335fa8="95gmc1500"]i have a 95 gmc 1500 serria with a 5.7 V8 and when i give it a little bit of gas once it goes back down to an idle it idles funny and then goes back to a normal idle[/quote:af37335fa8]
Check the IACV and clean the throttle body/plate.
May 25, 2007 at 9:36 PM
DANIMALGMC
  • 33 POSTS
It sounds like you might have a bad throttle position sensor.
Jun 11, 2007 at 8:14 AM
Suggested Repair
Check the idle air control valve (IACV) and clean the throttle body and throttle plate. A faulty throttle position sensor was also suggested as a possible cause.
Conversation Summary
The owner of a 1995 GMC Sierra 1500 with a 5.7 V8 reports that after a small throttle input the engine idles oddly, then returns to a normal idle. An expert advised checking the IACV and cleaning the throttle body and plate. Another reply suggested a bad throttle position sensor.
