2002 GMC Sierra Rough Idle
CWA1001
I have a 2002 gmc sierra 1500 5.3L with approx 70,000 miles. When I crank the vehicle in the mornings and drive for a couple of miles, I notice that when I stop, the idle pulsates. This tends to happen on mornings where the temperature is below 50 degrees. I had some check engine codes come up. P0171, and P0174. These are both bank 1 and bank 2 too lean. I took it to a mechanic and they said it was a loose snorkel tube. Thought everything was fine. Pulsating has returned, but no check engine lights. The truck feels like a muscle car with an oversized cam. It lurches against the brakes when I am at a stoplight. I have heard that it could be an intake manifold gasket. $$$ I am hoping someone can give me some other options.
Feb 28, 2007 at 3:28 AM
CHEVY22
  • 1,375 POSTS
it could be a leak at the intake with the lean codes , you could do the old backyard spray aound the engine to see it it idles different when thespay is applied and maybe check the idle air control motor on the throttle body when they faile they have the same effect on the idle
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 28, 2007 at 4:32 AM
Suggested Repair
Check for an intake vacuum leak with a spray test around the engine and inspect the idle air control motor on the throttle body. A loose intake snorkel was previously found and should also be rechecked.
Conversation Summary
The owner of a 2002 GMC Sierra 1500 5.3L reports a pulsating idle and lurching at stops on cold mornings below 50 degrees. Prior P0171 and P0174 lean codes were linked by a mechanic to a loose snorkel tube, but the idle problem returned without a check-engine light. The expert suggests an intake leak and checking the idle air control motor.
