2000 GMC Sierra No Start High Idle
KRISTI62489
I have a 2000 model GMC sierra it has a Vortec 4300 V6 engine with 75,000 miles. I love this truck but its doing me no good if i cant count on it to get me home at night. i got in in to go home the other day i put the key and and turned it to the start position and nothing happened no lights or anything so that happens a few more times and then it starts for just a few seconds before it dies. i finally get it to start but its ideling at aroung 2700 rpm's after a few minutes it goes to around 1000 and i take off but i notice that it is accelerating more without me pushing the gas. i have no clue what is wrong with it and i recently replaced the fuel filter. thank you for any suggestions
Feb 22, 2007 at 10:03 AM
CHEVY22
  • 1,375 POSTS
with all of that going on the pcm should be setting the engine light , is the light on ???
Feb 22, 2007 at 10:09 AM
KRISTI62489
no the engine light is not coming on
Feb 22, 2007 at 1:04 PM
CHEVY22
  • 1,375 POSTS
well we can start with when you said you turn the key and nothing happens , grab the battery cables and see if you can turn them by hand like a quarter of a turn and see what happens , if this gets you started the terminals need to be cleaned we will go from there
Feb 22, 2007 at 1:19 PM
Suggested Repair
Check the battery cables for looseness. If a terminal can be turned by hand about a quarter turn, clean the battery terminals and tighten the cables, then retest starting.
Conversation Summary
The owner of a 2000 GMC Sierra with a Vortec 4.3L V6 reports that turning the key sometimes produces no response or lights, followed by brief starts that die. When it runs, it may idle near 2700 rpm before dropping and accelerate without throttle input. The check engine light is off and the fuel filter was recently replaced. The expert advised checking whether the battery cables can be turned by hand and cleaning the terminals if they are loose.
