1996 Chevy Cheyenne 1500 Battery Charge
BHARGIS
1996 chevy cheyenne 1500
150,000 miles
Mar 7, 2006 at 11:10 AM
JPAM
  • 307 POSTS
S whats ur ?? how to change it out..
need motor size so someone can help u out better thnks,jess
Mar 7, 2006 at 3:08 PM
BHARGIS
sorry - yes - want to remove the alternator to have it tested
engine is a v8 305 5.7l
Mar 8, 2006 at 12:42 PM
NOS
  • 320 POSTS
disconnect the battery pos. take off surpentine belt take loose the battery wire on back of alt and unplug the field wire ,remove the two mounting bolts and remove alt. make sure you check all your big buss fuses sometimes that circut is fused also mak sure that you have a good charged battery. if you have to put on a new altrinator a low battery can damage new alt when you start it up a low battery can cause the reg to go wide open and blow the alt just do reverse when going back (NOS)
Mar 8, 2006 at 3:36 PM
BHARGIS
- just to give a little backround of why i'm having the alternator tested is because my battery would not hold it's charge. i just assumed the alternator was bad so i thought i'd have it tested.
thanks for the help
Mar 9, 2006 at 9:32 AM
NOS
  • 320 POSTS
you may think about you battery also a bad battery will also cause an alt not to charge and visaversa NOS
Mar 9, 2006 at 1:37 PM
Suggested Repair
Disconnect the battery positive cable, remove the serpentine belt, disconnect the battery wire and field plug at the alternator, and remove the two mounting bolts. Check the large bus fuses and test the battery as well. Fully charge the battery before installing a replacement alternator, because a low battery can overwork the regulator and damage a new unit. Reinstall in reverse order.
Conversation Summary
The owner of a 1996 Chevy Cheyenne 1500 with about 150,000 miles wanted to remove the alternator for testing because the battery would not hold a charge. The owner identified the engine as a V8 305 5.7L. An expert described disconnecting the battery, belt, and wiring, then unbolting the alternator, and also advised checking bus fuses and the battery. A weak battery can prevent charging and can damage a new alternator.
