fuse boxes and alternator not shutting off
1 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
AHOGG79
The alternator is staying on after you turn off the truck.
it's making beeping noise and is draining my battery I have replaced the same battery 3 times. How many fuse boxes does my truck have?
Sep 24, 2015 at 3:36 PM
HMAC300
  • 48,601 POSTS
there is only one fuse box, you have a draw it could be abad alternator diode bridge causing the problem. disconnect the large hot wire and see if the draw stops. you can go to how to repair diagrams electrical battery item 9
Sep 25, 2015 at 12:06 AM
