2004 GMC C1500 Steering Noise
2004 GMC C1500
62,000 MILES • V8 • 4WD • AUTOMATIC
JGRAY114
Hi I have a a steering noise only when i turn to the left, it sounds as the power steering fuild is low and after checking the level it was correct. Then I removed as much fuild as possiable from the resivior and filled with Lucas power steering fuild and for 3 days the steering was fine, although now its back to the same sound. When I removed the old fuild it had a burnt smell to it. Please help Im worried of losing the steering or breaking the belt.
Thank You
Scott
Mar 12, 2008 at 8:59 PM
EXTRAHANDSOH
the seals inside your psp are probly worn out as turning a vehicle to the left is more common to hear because that is where we sit at a stoplight with wheels slightly turned for the longest time try to replace the psp, if that fails check the seals in your steering box. you should also be under warranty from dealer return the truck to point of purchase.
Mar 12, 2008 at 9:22 PM
