brakes pull to the left
256,000 MILES
AUSERNAME123456
  • 106 POSTS
The brakes pull to the left. There are no warning lights on on the dash. What would cause the antilock brake system to just stop working?There is no fluid leaking anywhere and no air trapped in the system.
May 4, 2013 at 4:52 AM
could be a bad caliper, bad brake hose, wheel cylinder seized or rotors.
when was the last time you changed your brake fluid???
May 4, 2013 at 5:02 AM
AUSERNAME123456
  • 106 POSTS
I have not changed brake fluid ever. I have only added some as needed. So dirty brake fluid would cause this. I will have to get this changed. Thanks Roy for your answer.
May 4, 2013 at 5:11 AM
the dirty fluid is the cause of the failure of the parts. it is not the reason for the pulling
May 4, 2013 at 5:14 AM
