1995 Chevrolet Silverado Pulls Left Braking Fix
GOT2REPAIR
1995 Chevrolet C1500 Silverado Ext Cab
5.7L, Auto Transmission, 2 Wheel Drive
182,000 miles
Recently my truck started to pull to the left when I apply the brakes. When I have driven for some time, about three or more miles, the pulling get worst. Panic braking is really dangerous. I first replaced the brake pads and rotors, I also bled the brakes, but problem persisted. I then cycled the ABS by braking hard on a wet surface approximately ten times, hearing the motor buzzing each time. Bled the brakes again, all four wheels. Problem still persisted. I then replaced both front calipers, used the same brake pads (recently installed, 200 miles), and bled brakes, cycled the ABS, bled them again. Pulling to left still persisted. Thinking it may be the brake pads, I then swapped the brake pads from left side to right side, and vice versa, but pulling to the left still remained. Please help.
Aug 21, 2007 at 3:05 PM
CLY
  • 308 POSTS
Sounds like you may have a collapsed soft brake hose. I would suggest replacing both the front soft brake hoses and bleed the front brakes again.
Cly
Aug 21, 2007 at 9:51 PM
PENNY C MATURA
  • 5 POSTS
Thanks to Cly for his response. It fixed our 1995 Chevrolet brake problems! My husband says you are a genius!
Mar 23, 2020 at 5:39 AM
Thanks for the info. Glad this post helped you out. Please come back in the future if you need more info. If you don't find your answer in a post like this feel free to ask a question and we will help you out. Thanks
Mar 23, 2020 at 6:54 AM
Suggested Repair
Replace both front soft brake hoses, then bleed the front brakes.
Conversation Summary
A 1995 Chevrolet C1500 Silverado pulled left under braking, and the pull worsened after several miles of driving. Pads, rotors, and both front calipers were replaced, the brakes were bled, and the ABS was cycled, but the problem remained. An expert suspected a collapsed front soft brake hose and recommended replacing both front hoses and bleeding the front brakes. The owner later confirmed that this repair fixed the pulling.
