1997 GMC C1500 Truck won't start
TINMAN392
  • 1997 GMC C1500
  • V8
  • 4WD
  • 122,000 MILES
My truck has recently been a little sluggish to start. I let my wife take it to the gym and when she came out it wouldn't start. The motor turns over and I hear the fuel pump come on with the key (for about 2 seconds) but I'm not getting any ignition. I changed the fuel filter hoping that the old one was clogged. While I had the filter removed I turned on the key and the pump still only came on for a second or two. Is this normal? I have replaced the fuel pump, sending unit, wiring, etc. 4 previous times already (every two years). The truck is not tripping any faults. What do you all think?
Saturday, December 22nd, 2007 AT 8:55 PM
BLACKOP555
  • 10,371 POSTS
I think you should check for spark at the #1 spark plug.
The pump should only be on for 2 seconds and turn off with the "ignition click".
Your problem is more then likely spark related the spark should be bright, well defined, and blue.
Sunday, December 23rd, 2007 AT 8:16 AM
