replaced plugs, wires, cap, rotor, wires, and fuel filter, plenty of spark.
check fuel pump pressure was low at 8 PSI, changed pump, now holding at 13PSI. I get no fuel spray at TBI when I try to start engine, pinched return fuel still no spray and no start. If I use starting fluid the truck will start and run for a while then suddenly stalls you can hear the injector clicking when the engine is running Checked for codes with scanner, none, Could the computer be bad, and is there a way to have it checked?
Thanks Dave
SPONSORED LINKS
Friday, October 23rd, 2009 AT 11:26 PM
