yesterday in traffic my truck died, it slightly stumbled for the 1st three red lights after starting fine at work. the engine now turns over but will not start. FP pressure is 15psi, 11.94 volts at both fuel injectors, TPS good .5 volts closed & 4.5 at WOT, engine seems to have fire will start with starting fluid, disassembled fuel pressure regulator, no busted diaphram. what else could it be? what should i check next? thanks
Nov 21, 2009 at 5:51 AM
