If this is the old style distributor, check the pick up coil (eight star looking device) that connects to the HEI module.
You should see a low resistance with a multi-meter.
It is not uncommon for them to go bad.
Either that or it the ignition module (mounted under the dist. Cap) or the coil.
Good Luck
SPONSORED LINKS
Tuesday, June 12th, 2007 AT 2:36 PM
