1987 GMC C1500 truck no fire and flooding
MAGICKMAN858
  • 1987 GMC C1500
Electrical problem
1987 GMC C1500 V8 Four Wheel Drive Automatic
1987 gmc 1/2 ton no fire and floods out?
Wednesday, February 24th, 2010 AT 8:02 AM
HMAC300
  • 48,601 POSTS
It will flood if you dont' have fire. See if there is spark at the dist cap from the coil. If you do then it's probably a rotor or distributor cap. If not you'll have to check the switch in the distributor or see if there are any engine codes.
Saturday, February 27th, 2010 AT 3:14 PM
LOGGER9409
  • 27 POSTS
It is either the
1. The distributor cap and rotor
2. Or the IGNITION CONTROL MODULE. CHANGE IT
H.E.I. DISTRIBUTOR RIGHT?
Wednesday, March 10th, 2010 AT 4:28 PM
