92 GMC Sierra XCab, 2wd, 5.7 5spd man, 133k
Need to know how to separate the two piece drive shaft on this vehicle. There appears to be a seal concealed by a collar with a grease fitting on it at the splined slip joint in the middle of the assy. It rotates but does not screw off the splined shaft. The shafts will not come apart at the slip joint and I'm thinking the seal or collar is keeping them together. I'm resisting using shear force to pull it out...
Thanks,
Jon
Thanks,
Jon
Jul 22, 2007 at 8:50 AM
