1997 GMC C1500 4WD Won't Engage
VWRIPPER
i have 1997 gmc 1500 4wd 98000 miles can not get the 4wd to work in 4hi i have put a new trasfercase motor and a new axel motor to fuse are good to is there somthing iam missing
May 12, 2007 at 11:26 PM
E40WATER12
  • 522 POSTS
This may sound retarded, But when you are trying to put youre truck iinto 4 wheel drive, Have u locked youre hubs, Then also have you truck into N, Then try selecting youe 4 wheel drive into gear?.
May 23, 2007 at 8:29 PM
Suggested Repair
Lock the front hubs, shift the transmission to Neutral, then select 4HI.
Conversation Summary
The owner of a 1997 GMC 1500 4WD with 98,000 miles cannot engage 4HI. A new transfer case motor and axle actuator were installed and the fuses check good. The expert suggested locking the hubs, placing the transmission in Neutral, and then selecting 4WD.
