I am unable to remove glove compartment. Please help.
Dec 19, 2017 at 6:03 AM
Remove the glove box and frame as a unit. With the door closed, remove the lower dash-frame screws (diagrams show four or five). Open the door, remove the two upper screws, disconnect the switch connector, and pull the assembly out. Screws are the only retainers.
The owner of a 2006 Buick Lucerne could not remove the glove compartment and found only three of the expected lower screws plus the two upper screws. Experts advised removing the lower frame screws with the door closed, then the two upper screws and switch connector, and pulling the box and frame out together. A later reply said diagrams show five screws and that screws alone hold the box; no metal pins retain it.
