how do i remove a starter from a 1990 buick electra park avenue starter w/ a V6 engine and around 187,000 miles.
Jul 27, 2007 at 10:31 AM
Disconnect the battery, locate the starter at the front bottom center of the engine, disconnect the electrical wiring, and remove the two mounting bolts so the starter can come off. Install the replacement in reverse order.
The owner asked how to remove the starter on a 1990 Buick Electra Park Avenue with a V6 and about 187,000 miles. The expert advised disconnecting the battery, locating the starter at the front bottom center of the engine, removing the wiring and two mounting bolts, then reversing those steps to install a new starter.
