2007 Buick Lucerne AC Not Working
RIORIO1950
I have a 2007 lucerne. For the last 3 months, the car has been in the shop because the air doesn't work.
The compressor has been changed 3 times.
there is always debre in the lines that has to be cleaned.
Now they have to replace the accumulator or cumulator and the TXV which is a major job. It will be a week again, before I get it back. Been in the shop for the last 2 months every other week.
How serious is this? Should I keep the car?
Jul 24, 2007 at 6:02 AM
CLY
  • 308 POSTS
I would venture to say that the first compressor that went out must have really had a major break-down. All the metal went through the system and that is what keeps pluging up that orifice tube. Chances are that several componets will have to be replaced in order to get all that stuff out of the system....I have not seen hardly any problems out the A/C systems on the Lucerne. They really are good cars....
Cly
Jul 24, 2007 at 10:21 AM
Suggested Repair
Treat the original compressor failure as a system-wide contamination event. Replace the accumulator and TXV, flush all lines and remaining components to remove metal debris, and only then install a new compressor so the orifice does not clog again.
Conversation Summary
The owner of a 2007 Buick Lucerne reports the air conditioner has been in the shop for months. The compressor has been replaced three times because debris keeps appearing in the lines, and the shop now wants to replace the accumulator and TXV. The expert says the first compressor likely failed severely and sent metal through the system, so several components must be replaced and the debris fully removed. Lucerne A/C systems are otherwise described as generally reliable.
