Remove distributor cap crank engine make sure rotor is turning as engine cranks
Disconnect electrical connector from distributor.
Turn ignition on. Using voltmeter, check voltage between Black/Orange wire of distributor connector and ground. If battery voltage does not exist, check for open circuit in Black/Orange wire between distributor connector and ignition switch.
SPONSORED LINKS
Tuesday, January 12th, 2010 AT 6:01 AM
