1991 Geo Prizm Car won't start.
OCONNORML
  • 1991 GEO PRIZM
  • 4 CYL
  • MANUAL
  • 189,000 MILES
I just started my car, backed up a couple of feet, then the engine quit. It won't start again. The lights work, so I don't think that it is the battery. The gas tank is full.
Sunday, November 9th, 2008 AT 5:27 PM
MMPRINCE4000
  • 8,548 POSTS
Remove the timing belt cover and inspect the timing belt, see if it is broke.
If OK, then check spark. If no spark, I would suspect an ignitor, which is in the dist. And can be removed and tested.
If spark, is OK then check fuel pressure. On these models, you need a special adapter. Remove the cold start valve and screw in adapter to fuel rail, connect other end to fuel pressure tester.
Monday, November 10th, 2008 AT 8:52 AM
